I know this is an old thread, but has anybody experienced a vacuum leak and the break pedal going to the floor? Please help.
Yes, after I did the whole replacement that was the code that came up.Not sure if the oil cooler replacement thread is what you wanted. Is this a problem you had after the replacement?
I've worked on this leak 3 times. Replaced cooler with amazon one. Pinched oring, replaced all seals on the new one, replaced oring on feed tube with thicker one. Started leaking after a week .
I wonder if the housing itself is bad.
Can a 2019 or -18 fit? Way big price difference from 2015.
As long as you check the oil level you should be fine. Swap was time consuming but pretty easy. Just be careful when you take the little plastic clip off the fuel rail.
Updated with pictures. I wish I had some action shots of me doing the work to better aid but I'm only one man. Lol hope this helps someone someday.
