He's looking the other way, I think you can get the one you want.....
I love that old saying. One is none and two is one.
One is none. Two is one.I guess it’s time for a front axle rebuild.Locker? Disc brakes?
While totally unnecessary or at least, in my book, disc brakes would be nice. Unless you're planning on wheeling this thing, no need for lockers.The only thing more hungry for your money than a Jeep is an Old Jeep!
While looking around under the hood I discovered this
When my lovely wife asked how I was going to fix it, I explained the “One is none, two is one” theory. I’d order a new radiator and have the old one rebuilt, that way I’d have a spare……she just shook her head and walked away.
In addition to the radiator leak I discovered that my front axle seals were leaking and that my front driver wheel/tire had way more rolling resistance than it should. I guess it’s time for a front axle rebuild.Locker? Disc brakes?
I don't know. Seems to me you have an easy way to check your fluid levels now. If its leaking its got some, if it stops its out.The only thing more hungry for your money than a Jeep is an Old Jeep!
Piginajeep and I have talked about doing an old iron run out here. Might have to make it happen once you get out hereI go back and forth on whether I want to wheel it or keep it pristine. If I do wheel it, I would only do easy trails in places like Northern Nevada or Utah, and if I were to put something in the front axle it would be a limited-slip and not a true locker.
What I really need is an over-drive so I can finally break the 52 mph barrier!
Right now this is me at 51 mph
Started the day I bought it lolHave you ever started a simple Jeep project and it just keeps expanding? It’s like a Black-Hole that continues to increase in size and begins to consume everything in the universe?
Old farts working on old parts.Have you ever started a simple Jeep project and it just keeps expanding? It’s like a Black-Hole that continues to increase in size and begins to consume everything in the universe?
Silly question because that’s usually the rule and not the exception- especially when the Jeep is 77 years old!
After some issues stopping I decided to check out my brakes. I jacked the front driver side up and discovered something was ‘going on’. There was heavy friction and a grinding noise when I spun the wheel.
Easy day, I’ll just take the tire/wheel off and pop the brake drum off. First off some of my wheel studs are reverse threaded.
To add to the complexity, in order to get the drum off you must pull the hubs and the nuts and washers underneath.
Somebody used a chisel or screw driver on this bearing adjuster nut.
Good times! It will be better than it was!Have you ever started a simple Jeep project and it just keeps expanding? It’s like a Black-Hole that continues to increase in size and begins to consume everything in the universe?
