JKbrick
I went off this screenshot but it’s been so long ago I don’t have a clue where I saw it. Probably the internet so it’s got to be right, right?
Installed the front shock towers, motor mounts, proportioning valve, heavy duty steering box bracket,the steering box and started to install brake and fuel lines.
I blindly believe everything I see on the internet....
Did you start with a new frame? Or blast the old and powder coat?
Blasted and Chassis Saver. Although I'm starting to think I should have power coated.
It looks really clean. Nice job.
Is that a 304 I see in the background?
Thanks. Why yes that is a 304. A PO swapped in a 304/T150/Dana 20 from the 78 CJ7. It's a great engine, ran great and no problems before I broke down the Jeep. But the T150 has to go. On the dunes, I have to run in 4lo to have any kind of climbing power. The T150's 1st gear just isn't deep enough. Eventually, I want to swap in a 4 or 5 speed.
I looked on the internet and didn't see any pics for the EVO rear arms orientation. I installed them this way for two reasons. 1) The bend seemed to match up with the factory arm. 2) It's easier to drop the body side mount to make adjustments without removing the rear tires. The arms clear both rear tires now, so I'll keep it this way until I see installation instructions proving otherwise.
I never meant yours were wrong, I just wondered if it even mattered which way they are installed, mine seem to fit and don’t rub either
Just installed Crown heavy duty steering kit on my sons TJ, was pretty impressed with the quality. Tons better than the Rusty’s kit that only lasted 18 months or so
Nice, did it help with the shimmy your son has been having?
So far so good!his sway bar links are bad so that is next but he said it drove good going home last night
