JKbrick
FYI, there’s an update for iPhones to fix that damned A question mark glitch,
Mine just did it, is it an iOS update?
Absolutely convinced they sabotage our phones when a new one comes out.
Mine is half ass unusable after the latest update.
Some Video i got of Exodus Jeeps, Mike_JK-Houston, and JJK going up a red marked rock, it was pretty easy, considering some of the more difficult stuff we ran across was only marked yellow
Video of JJK GOing over this difficult yellow
I agree. Seems like once my contract is up or close to it every time my phone shits the bed. So stupid.
That place looks fun. I want to check out Las Cruces sometime as well.
Way to put the jeep to use! I wonder if evo would replace it. Unless it’s re-weldable
Hey Benito, I thought I would check in to see what's new since your last trip and give you a huge bravo for getting your 2017 done so quickly. Has to be a record start to finish. I have been banging on mine since July.
Hey man, thanks. Nothing much new, i got the coilovers installed, and removed the cage so i could take it to get powder coated. thanks to the all Black Friday sales i got bumpstops and fenderliners ordered. Just for reference, since July 3rd, this Jeep has had three different axle sets (factory 44s, old PR44/trussed44, PR60/Pro60), five different iteration of suspensions (factory, 3” Enforcer, 3” High clearance long arm, 4” high clearance long arm, bolt on coilover high clearance long arm), and 3 different sets of wheel/tires (factory, 37” Nitto trail grapplers on ATX Slabs, and 40” Nitto Trail grapplers on ATX Chamber Pros)
:cheesy: Sounds like you've done enough this year alone to last 10 years :crazyeyes:
After all the work I have done, I couldn't think about mounting / un-mounting three sets of deadlocks, let alone axles. Did you upgrade to the PSC XDII?
Lookin good manBuild update!
After installing the rear coilovers and running it for a couple of weeks it was clear that i did not have enough up-travel and was bottoming out the shocks w/4” bumpstop extensions installed. I had no preload and was sitting pretty high in the rear, i had/have about 2.5” of preload in the front. It was clear my shock mounts with all of their clearance wasn’t going to work with the coilovers. I let Bubba over at Exodus Jeeps take care of it. He fabbed up some new lower shock mounts that lowered the mount and allowed for some more up travel, it now has about 1.25” of preload. While the Jeep was at Exodus Jeeps i also had some King Air bumps installed, can’t wait to put them to use!
This is what my shock mounts looked like before
These are the mounts Bubba fabricated
And the air bumpstops
I installed the Evo Fender liners and i have to say, these had by far the worse instructions Evo has put out. There isn’t even a picture of the final install! But they look good and cleaned up the front end really well!
I also got the cage back from powder coat and installed the cage today. Here are a few pictures
