Got the ARB breather kit installed. Very easy. For the diffs, I just heated up the plastic line that ARB sent and opened it up with needle nose pliers to make it fit the larger fittings in the axles. For the tcase and transmission, I ended up just sliding the ARB into the OEM rubber line about 3 inches or so and zip-tied it really good, it was a tight fit without the zip ties so I think I'll be fine. I did this because I was running short on tubing, as well as those two gear boxes were really hard to reach and had to get to the fitting on the gear box.
Rear diff:
Front diff:
Transmission has had to breathe a time or two it looks like:
Manifold all fitted cozy next to the Chipotle intake:
For OCD's sake I masked off the axles and tcase with foil and FlexSealed the ends of the breather hoses:
