So I removed my OEM rear 12volt power supply and capped off the power wire. Then I rewired the circuit with 8 gauge wire to my aftermarket auxillary power source and put the OEM socket back in its original location. I just installed a 15amp fuse as ARB calls for and fridge seems to be working fine. And I can still access the fridge through the rear glass without opening the rear hatch.
Nice work man, you are going to love it. I would recommend throwing in a thermometer and letting it run for a while with water bottles or something in there. My temp is pretty far off of actual... But once I found the offset it has worked flawlessly. Just remember the little cubby up top runs warmer, so even though it's handy for waters etc, they won't be the coldest.So I removed my OEM rear 12volt power supply and capped off the power wire. Then I rewired the circuit with 8 gauge wire to my aftermarket auxillary power source and put the OEM socket back in its original location. I just installed a 15amp fuse as ARB calls for and fridge seems to be working fine. And I can still access the fridge through the rear glass without opening the rear hatch.
I'm jealous!
Congrats on the purchase, now you really can keep the IPA's in the ARB :beer::beer::beer:
That is cool, I am yet to get one of the Arb fridges..... you do a ton of work on you WJ btw. That's kind of inspiring I must say, I look up to guys like you on Wayalife and build courage to do shit on my own Jeep. Thank you [emoji482]
Nice! That fridge is definitely on my want list, but I've got a few things ahead of it in order of "necessity." Enjoy!
Sent from my SM-N915P using WAYALIFE mobile app
Sent from my SM-G955U using WAYALIFE mobile app
I'm not so sure that I needed it either, but we're starting to get out more with the kids and are constantly carrying an ice chest. Hopefully this will make things easier.
Thanks for the tips. So does yours display a colder or warmer temperature than what's actually inside?
Hey, I carry an ice chest with me all summer in my work van... I could use that as an excuse to bump it up on my priority list AND count it as a business expense.
This is good advice...I set mine to 32, but found out it was running about 38 after letting it cool down for a day...and the top compartment runs warmer...I usually only put fruit there. I now set it at 27...
Mine runs warmer than the display. I keep in in Celsius just cause I use it at work and am used to it haha... 0 is 32... I have mine set for -2 or -3 if I recall so it's set for 26 or 28F.
At this temp things at the bottom don't freeze but are real close, and the cubby up top is good for cheese, lunch meat, condiments etc.
Congrats! I want an arb but don't go out for long enough in the Jeep to need one. Just a cooler does great for me
Couple of good ones I snapped of your rig from this weekend
There's a way to offset the display reading to better calibrate it to the actual temp inside the fridge. I believe you hold down the + and - temp buttons and you can shift the reading up to 8 degrees each way.
I use mine as much away from the jeep as I do in the jeep. [emoji106] rolling into a hotel room with a fully stocked fridge for a few weeks is the way to go!
Good info, didn't know about this! Once I got it dialed in I just left it and don't even look at the setting anymore.There's a way to offset the display reading to better calibrate it to the actual temp inside the fridge. I believe you hold down the + and - temp buttons and you can shift the reading up to 8 degrees each way.
