WJCO
Meme King
So I finally got to adjusting mine according to this Dynatrac diagram and taking it for a test ride. It made the higher speed handling noticeably better. I have mine set at 6* now. Surprising what 3* change will do.
75mph & over was ambitious. Now its single hand on the steering wheel good. I hit 85 no problem. For guys running the PR44 with the unlimited geometry, it would probably be worth the $10 to get a cheap angle finder at HF or the like & check yours. If the alignment shops are setting your specs to stock they may be off. Thanks WJCO for posting that diagram.
This is at 70+ mph
Glad that worked out for you. :thumb:
