Is caster relative to the angle that the frame is. I have the RK 2.5 max travel, stock bumpers and the rear sets high.
89* garage floor angle
91* frame and roof
90* bolt hole on front axle
96* top of ball joint
2* rear drive shaft / pinion difference
If the rig is loaded and level does that change the caster.
I see a caster of +7*. Is that correct .
It is relative to the angle of the frame/ground/etc. If you have 96 on the ball joint, and the ground the Jeep is sitting on is zero, then you have 6 degrees caster. I like parking it on clean cement and measuring the ball joint, then measuring the concrete right under the ball joint. So if I were to get 96 at the ball joint and 1 on the ground, my caster is 5.
EDIT: Sure looks like you have 7, but that seems like a lot. I'm guessing your lower arms are adjusted too long.
