WJCO
Meme King
I'm going to call ORE today and see what they say. If I step down to 3" springs it would reduce the angle more. Maybe the 4" just isn't a good choice without a new front axle.
I don't have much adjustment on my LCA's to reduce caster anyway.
Lots of guys run 4 inch lifts with proper caster and don't have to replace their axle. See what ORE says though. If you can't get the caster any lower with your lower arms, you may have to buy upper arms and make those a little longer. If you haven't already, don't forget to measure the angle of the ground the Jeep is parked on when calculating your actual caster.
EDIT: I just re-read your other posts. Any chance you bent the driveshaft or threw a weight off while you were on the trail? Also ensure the pinion yoke and tcase yoke are properly torqued.
