AZ Explorer
Looks like I got a project tomorrow.
Should be a breeze compared to the other projects you've had lately. :crazyeyes:
I have that socket in my bag of goodies in the "shop".Hopefully. Need to go pick up a few things to get the job done. I don't just have a 36mm socket laying around. Haha
Told the girl plan for 4 hours. Hopefully I get done fast and can put the cage in too without her noticing. Haha
How do you know when they need to be replaced?
Changed the last one when on a road trip in Colorado
People keep saying red, but I don't remember you having any red. Of course, I've got a shitty memory!
I'd probably go with a black dash bar and do the rest yellow to match the factory bars.
Do the bars running front to back yellow and the bars going from side to side red... or vise versa.sorry i missed this earlier. and i don't really have a lot of red on my jeep. just the grill and 1 Dynatrac sticker.
dash bar will be black for sure! however i keep going back between yellow and red. so maybe i will do the driver side red and passenger yellow.
But on a good note NABOO is still functional as a grocery getter!!
And it's a beautiful day in LA so I did it stripped down.
Good luck with the DW. FYI, when you pull the bolt look at the threads. I just posted this a couple weeks ago: https://wayalife.com/showthread.php...n-Do-to-Fix-it?p=907059&viewfull=1#post907059
When I installed my ProRock, I was a dumbass and overtorqued the bolt and stretched the threads. A new bolt with the proper torque fixed it and it is so nice to drive now. 2nd best thing I've felt in awhile. Good luck.
Good to know! Where did you get the new nut and bolt? Want to be prepared if this is the case.
This is on a jk axle on my WJ, so it's a 12mm bolt. I'm pretty sure the jk one on yours will be a 14mm. I just got a grade 10 bolt at Ace hardware and with the proper torque, it worked fine. Like you stated already, definitely make sure holes are still round as well.
So the bolt is fine the track bar bushing seems to be shot. If it's the original one from the jeep then it has 96k miles on it. so due for a replacement.
The bushing on the 11 and older is solid. It's bonded rubber on the newer ones. The newer ones can go bad, the older ones wouldn't go bad, maybe just oval out. If it's a factory the bushing can't be shot.
