USMC Wrangler
Looking good
Thanks! [emoji106] I know it's not much to look at right now. Getting the holes drilled with the front plate square and centered was the first hurdle in my mind. I do not have a drill press, so power drill and step bits was the process. That was fun with 1/4". Lots of cutting oil was dumped on! [emoji15]
Good start! I have been thinking about this since you first mentioned it so I will be following closely! I can design, cut and do the machine work. The problem for me is the welding. I only have access to a 30+ year old Miller stick or I can have a local shop TIG it together? I would rather do it myself so I guess its time to lay down some practice beads!
I'm sure the stick welder would do the trick. I plan on tacking with the mig option on my Lincoln 210 and probably finish with stick. I'm not sure how long my little bottle of mixed gas will last and it's pretty windy here. That's why I have it in my mind to finish the welds with stick. I have 50 lbs of 7018 vs 8lbs of mig wire on hand.
Love the versatility of the 210. Someday I'll get the tig setup for it and give that a spin. I've never run tig and want to eventually.
I love designing, but the actual building is almost therapeutic for me. I don't know how else to explain it.
