Name That JEEP Part
Weekly parts roundup part 1
Here's a complete catalog of all parts submitted with the correct answers. Many thanks to all that participated in this crazy thread. I hope it keeps going... Now get out in the garage and dig up some old JEEP parrts.
Exhaust Isolater. Submitted by Me.
Sway Bar Link. Submitted by 10frank9
E-Disconnect Connector Gasket. Submitted by JAGS
Automatic transmission cooler elbow. Submitted by Me
One Broken T-Case shifter cable bushing. Submitted by WAYALIFE
One new T-Case shifter cable bushing
Track bars.Top one goes in the rear.Bottom one goes up front.125 ft. lbs. using a 21mm socket. Submitted by Me
Oil pressure sensor. Submitted by Trail JK
E-disco motor actuator. Submitted by Moochie
Front axle wheel hub, inside the knuckle. Unit bearing bolt. Submitted by Me
EGR Valve for a 3.8. Submitted by highoctane
Windsheild Header Weatherstrip Rivits. Submitted by Me
Dana 44 Pinion Gear Crush Sleeve. Submitted by Me
Fender Retaining Clip. Submitted by Me
Weekly parts roundup part 2
Cat to header flange nut thingy. Submitted by Me
Loose Lug nut. Torque Spec 85-90 for aluminum wheels and 100 for steel. Submitted by OverlanderJK
Upper track bar flag nut. Submitted by Me
Glove box light switch. Submitted by WJCO
E brake drum brake spring. Submitted by WJCO
ABS wheel speed sensor. Submitted by Benito.
3.8 Engine Shortblock, AKA Smokey! Submitted by Moochie.
Fender liner bolt. Submitted by Me
Fog lights left 07-11 and right '12+. Submitted by Me
Axle bearing. Submitted by RockyJk
Speed sensor clip. Submitted by Me
The bolt that holds the door mirror to the bracket. Submitted by WAYOFLIFE.
Easter egg on the small vent on a Renegade's rear view mirror housing. Submitted by JAGS.
Sun visor escutcheon. Submitted by WAYOFLIFE
Weekly parts roundup part 3
Disc brake pad hardware. Often called Brake pad, Anti-Rattle or Abutment Clips. And badly need lube. Submitted by Me
The deal on the rear door where the frame surround compresses. Submitted by WAYOFLIFE
Track bar or lower control arm bolt. Grade 10.9 and you need a 21mm socket for it. Submitted by Me
Bracket for the factory rear bumper. Submitted by MedixJK
E-Brake cable retainer above rear axle. Submitted by WAYOFLIFE
Obviously not JEEP parts but, important nonetheless. Pinon nut and axle nut sockets. Submitted by MedixJK
EVAP Support Bracket. Submitted by Me
Brake caliper slide pin boot. Submitted by Me
Auto Trans skid plate from a 2009 JKU. There was something very wrong with these parts, check out posts #223-240 for some great info.
Battery hold down clamp. Submitted by WAYOFLIFE.
Belt tensioner from a 2009 JKU. Submitted by Me.
Air filter housing hold down grommet. Unconfirmed. Submitted by WAYOFLIFE.
Dana 44 axle stub shaft. Submitted by Me.
Rear sway bar end. Submitted by JAGS
Weekly parts roundup part 4
It is a plug that fills in the rocker switch holes on a TJ. Submitted by JKBRICK
Muffler heat Sheild from a 2009 JKU
U-Bolt from a 1310 driveshaft.
The nut that slides into the pinch seem for stock sliders or steps. Submitted by WAYOFLIFE
Broken D30 Left front u-joint. Submitted by drtnwtr
Soft top bracket.
Although not OEM, these bolts are intended to attach the soft top bracket to the roll bar. Submitted by Heholua
Soft top bow frame bolt.
Rear upper shock mount bolts. Submitted by Heholua
Brake Caliper bleeder screw cover.
Speed sensor hole in the unit bearing. Submitted by OverlanderJK
Horn Grill Submitted by DDays
Speedo Gear
Oile filter bypass valve, 2012-2013 3.6 Pentastar Engine Submitted by Suds
Axle Bearing. Submitted by MTG
Steering gear pitman arm nut and washer. Torque Spec 185 ft lbs
WOW!!! That was a lot of parts. Stay tuned for more fun...
In what year make and model Jeep vehicle would you typically see this part?
A. 83-86 CJ series
B. 84-86 Cherokee with a AMC 2.5L engine.
C. 87 Wrangler YJ with a 4.2 engine.
D. All of the above.
Name that part...
A. Ignition relay
B. Rectifier Bridge
C. Starter Solenoid
D. Circuit Breaker from Sharkey's Jeep solar panel array.
A. 83-86 CJ series
Name that part...
A. Ignition relay
B. Rectifier Bridge
C. Starter Solenoid
It must be old it says made in USA on it
