I thought it would be fun to start a thread dedicated to the carnage most of us have seen over the years. To kick things off, here are a few shots of body damage and breaks that Moby has seen.
Probably one of the worst breaks you can have - a sector shaft, taken out on the Rubicon...
It'll rub right out!! :cheesy: A little carnage on Moby compliments of Carnage Canyon BV....
Custom rear sway bar break thanks to Billings Canyon...
A summer of hard wheeling gave our Spyderlock rings a working and bent our rear axle shaft flanges as well...
If it can be broken, there's a good chance that we'll break it. Shot right after breaking our semi-float ProRock 60 rear axle shaft at the flange on Double Whammy...
As you can see from the ring of rust, it had been failing for quite some time. Perfect excuse to go full-float...
Kiss from a tree on the Dusy Ershim. As you can see, I wasn't the first to get the love tap and, I doubt I'll be the last...
Blown out rear end also compliments of the Dusy Ershim. Should have known better than to run a 5.38 ring & pinion in a Dana 44 rear axle pushing 40x15.50's...
Here are some shots of a chromoly front dana 44 shaft after being played hard on for about a year...
Sure would have been nice if the darn shaft had just broken at the U-joint. Here are a couple of shots of what it ended up doing to locker, bearings and housing...
Broken front track bar mounts compliments of the Bronco Peak Connector...
Trust me, there's a lot more than that and if I can think of it and or find pics of other breaks, rock rash and trail damage, I'll be sure to post them up. In the mean time, how about we see some of your pics!!
:thumb:
:thumb:
![382121_4461220045980_1225262861_n[1].jpg 382121_4461220045980_1225262861_n[1].jpg](https://www.wayalife.com/data/attachments/5/5658-44f1ec4fc0f38ce056dee965f197a0cc.jpg)
