JT@623
Turned out niceWrapping up this build. Really happy with it and like the stance of the 42’s with 72.5” wide axles.
Thank you. Drives great too, almost forget you are on 42's.Turned out nice![]()
Very nice! What gear ratio in the diff turning those 42’s?Wrapping up this build. Really happy with it and like the stance of the 42’s with 72.5” wide axles.
Thanks! 5.38’s. This is also a manual 3.8LVery nice! What gear ratio in the diff turning those 42’s?
I was going to ask if it had a V-8 swap. I can't imagine running 42's with the 3.8LThanks! 5.38’s. This is also a manual 3.8L![]()
Actually didn’t feel bad. He doesn’t daily it though and trailers it everywhere.I was going to ask if it had a V-8 swap. I can't imagine running 42's with the 3.8L
Makes it a little better. Still stepping on the throttle and hearing a whine vs a roar just isn't the same...hahaActually didn’t feel bad. He doesn’t daily it though and trailers it everywhere.
Need to save this post for future referenceI think it has been brought up or asked several times regarding the use of cam bolts for caster adjustment or going from a cam bolt back to a standard bolt.
Well, this is what it looks like after cam bolts have been installed….You can clearly see why a standard bolt will now not work. This is also why it is recommended to install adjustable control arms over cam bolts.
