Slight movement in Ball Joint
On my last tire rotation my mechanic mentioned I have a light play on my driver side ball joint (synergy) with about 8,100 miles on it.
I have not noticed anything driving yet, so at what point do I need to address this issue?
Rotational movement is 100% normal. A shifting side to side or up and down is an indication of a worn out joint. Unless your mechanic specified what he was seeing, I would say he's just trying to upsell you on work you don't need.
Thanks I'll double check it and get a second opinion.
What do you think of the Teraflex ball joints? Sounds like resetting them is a big plus. My 13 JK, 2dr is on an ultimate dana 44 axle with 33" tires and a 3.5" lift.
Synergy Ball Joints are what we usually install. With low mileage, may be worth a call to them for a possible warranty replacement. I’d be surprised though if it was in fact actually bad at 8k. Maybe they were never greased during installed or not properly torqued.
Just be careful and pay attention to your current ones if they are knurled or non-knurled (won’t know until you remove). They should be NON. I bring this up because we see people throw in Knurled when they shouldn’t all the time. If knurled were installed, you need to stay with them 👍🏼
Not really a fan of anything Teraflex but even if I were, these seem kind of pricey for just a set of heavy duty ball joints. MOST HD ball joints are more than good enough, certainly way better than OE and will last a long time. Synergy, Crown and the like all make good ones that I would run on my Jeep and they cost a lot less.
