As some of you may know I am currently building a house and was curious what some of you have added to your house that is a must have and some things you hate. I just finished framing the inside so now is the time to add as I do electrical and whatnot.
So anything that is a must have in a home that you added or would like to add?
Run ethernet wire from every room (with rj-45 plugs) to a central closet or the garage if attached. Put a ethernet switch in that room and wire that to your broadband router. Then you don't need to mess with wifi.
A whole house fan or smart-vent system is also a great money saver for those warm afternoons where the house is hotter inside then outside.
I'd add a cigar room with ventilation and all the man-cave fixings so you don't have to sit outside in the cold/heat to enjoy a Cuban cigar.
For me, no carpets in any room. My current house had hardwood floors in the kitchen, main rooms, but not the bedrooms. I can use a dust mop on the hardwood and have it all swept in 5 minutes. The bedrooms, not so much.
Wire the garage for 220V so you can run a high-capacity compressor, welder and plasma cutter.
Run an hard air line around the circumference of the garage with several quick connects on each wall.
Add more electrical wall plugs to the walls. There are never enough in the garage.
Have plugs put into the garage ceiling so you can run those fluorescent tube style LED lights.
Get some reinforcement built into the garage ceiling so you can hang sliding/rolling hoist beams.
Definitely a wood burning stove inside the house. And maybe one in the garage.
Oh, and plumbing in the garage as well for a utility sink.
Pre-wire and install a switch panel for a generator.
