Was way overconfident in how much time it would take....
spark plugs and coils:
Didn't start the ball joints until 2pm, I really felt I'd have one side completed within a couple of hours... let me say how much I am now hating aluminum knuckles; the hubs were seized/welded in, took over an hour to break them loose.
Took at least 30 minutes to ring the ball joints loose, getting a ball joint separator for the other side.
Tried the reverse disc as a slide hammer, inserted bolts and using an extra 13mm/12pt socket, beat them with the 5lb sledge and they finally broke loose... an hour!!!
Close up of corrosion and pitting this is all around the where the hub sites
I was surprised to see how well the brake pads were holding up with over 111000 miles, the wear indicator is close enough I'll be replacing them all around while apart.
So, this is how it sits for now, I'm ordering Synergy knuckles, aluminum knuckles to the recycler.
Already have new Mopar hubs to install; fyi, the hubs Autopart stores have that they state will fit, have smaller lug nut bolts like the JK.
Technically the hubs felt solid and reusable but the amount of rust and beating I gave them to remove them... new ones going on.
Will be installing Revolution axle shafts, waiting on a couple of replacement parts and will wait for the new knuckles.
Will likely do brake pads all around tomorrow and lube the arms.
