Moochie
Not vice grips. BTW how did you hook up the disconnect switch on your battery? Very interesting. Also do you have the King Coilover bolt on kit?
R/
Will
I picked up that battery disconnect at Camping World. It is used on the negative post. I need to cut the power when I tow the Jeep behind my RV because the key is turned to the first position to unlock the steering. Required 2007 - 2009. If not, it will cause the battery to discharge over a long tow.
That's the bolt on coilover suspension kit from EVO Manufacturing. It uses King coilovers designed & valved for EVO.
You have a good eye, you spotted the vice grips.
