Sweet! Looking forward to seeing your progress!MOTECH gen V LS kit.
Awesome!Just finished wiring up the elements fridge in the JT… there went 1/3 of my bed space. Lol
Also, it sits basically flush with the bed rails… meaning a tonneau is out once I get this thing mounted on a slide.
Just a little regular maintenance. Changed air and cabin filters, then did an oil change
I’ve got gear oil and transmission next round. I’ve never done the transmission and I’ve got the 6 speed, so that’ll be an adventure.A little of the same here.... Engine & Gear Oil Change.
Yeah... Transfer case & Trans are on my future list as well.I’ve got gear oil and transmission next round. I’ve never done the transmission and I’ve got the 6 speed, so that’ll be an adventure.
Thats cool ill have to look into that.I have a XJ too that id like to swap rear discs into.I should have made that picture smaller.
It does look a couple degrees too lowDoes this look right? Bad picture of the angle finder but as far as I can see it say's about 2 or 3 degrees.
This ^^^ Looks visibly low.It does look a couple degrees too low
Yea this is really discouraging. Getting a little pissed off at this whole thing. Looking around at the work that was done ( High clearance long arm install) I have already found front lower control arm bolt missing (axle side. 250 mile drive home could have gone really bad). Day before yesterday a CEL pops up P2098 catalyst fuel trim (Cat had to be modified during install). This pinion angle and being left with 1/2" of travel on rear bumps.This ^^^ Looks visibly low.
Well that's a bummer. Might want to make a list of all the things you're finding and take your Jeep back to the shop that worked on it. Politely let them know that you're disappointed and that you would be grateful if they could please address them in a timely manner.Yea this is really discouraging. Getting a little pissed off at this whole thing. Looking around at the work that was done ( High clearance long arm install) I have already found front lower control arm bolt missing (axle side. 250 mile drive home could have gone really bad). Day before yesterday a CEL pops up P2098 catalyst fuel trim (Cat had to be modified during install). This pinion angle and being left with 1/2" of travel on rear bumps.
