14.2" rotor mock up!!
How about a few sexy pics of a factory 14.2" (yes - you heard me right - not a 13"... a
14") rotor sitting behind a stock JK rim??? Here ya go!!
First, the OEM setup:
Now the two discs, stock and upgrade, side by side:
14" rotor on hub:
14" rotor behind wheel
14" rotor behind wheel, with stock caliper
The discussion:
So the rotor fits beautifully!! The only catch I found is that the outermost edge (facing the back of the wheel spokes) of the stock JK caliper contacts the rim.
This is solely an issue with the stock JK rim, due to an approx 1" raised lip imediately behind the spokes that effectively narrows the inner diameter of the rim by nearly an inch. This is only an issue on factory rims. If you are running at least a 1" spacer behind your wheels, or any wheel with at least 1" LESS backspacing that stock (approx 5.25" or less, which is MOST JK aftermarket rims), then this isn't an issue.
It is so close that I still was able to lightly place the rim on the wheel studs long enough to take a few pics.
Given the simple physics behind braking, I feel that pushing the envelope for the largest 'fittable' rotor as possible is the easiest way to the most
noticeable braking improvement. The gross brake torque increase in this case, if you were able to simply reuse your factory caliper, is
19.3%!!! Again, that is without change in master cylinder, and no change in caliper. Nearly 20% better!!! YAY!! :rock:
So....
Isn't that a big-ass, sexy rotor??! Look at the side by sides of the two rotors on the floor next to each other!! DAMN...!
We are one step closer!!
Up next: calculations comparing master cylinder bores to the caliper piston area sizes. This is something that, to maintain a stock-feeling (or better) brake pedal, must be kept in mind!
After that, finding a suitable, big-ass (but low-profile) caliper! Stay tuned!!
