Really? I thought yours was much higher. I'm trying to go as high as I can without having to change half the parts. How high would you recommend? I want to put 35's
Well past about 2.5" you will start to run into a front driveshaft issue, and you will need a drag link flip to help with steering geometry. And also setting your caster when you get above that as well. If your plans are just to do 35s then I would stick close to 2.5 or 3. Anything above that you start needing more and more to ad on. Just my 2 cents
Nice, looks good. I'll have to find a place to do that. I can barely turn a wrench let alone weld. Like those rims too, thinking of going with the trackers from the same company.
Thanks for the input fellas. Really appreciate it.
Of u could just cut you flares and add a leveling kit for about 1/4 of that price and easy run 35s. Here's my EVO leveling kit with 35s.
I'll gladly sell you my kit for cheap.
Forgive my ignorance, but what's the difference between a lift and leveling kit?
There are different types, but EVOs kit is 2" coils up front and 3/4 inch spacer in the rear.
Levels out the jeep(gets rid of the rake) but doesn't mess with the geometry of the jeep as much so a lot less is needed. Maintaining factory quality ride
Some kits use only spacers front/rear but the front factory coils will sag a lot if you add a bumper/winch/etc...
