notnalc68
That dude from Mississippi
So over the weekend I went on the Slaughterhouse trail with some others here and had some difficulty on a steep hill. H8ROADS said at one point he noticed my front drive shaft was spinning but not my front tires. Come to find out, the LSD carrier in these WJs are fluid actuated and can have issues getting air in the carrier on steep hills and not be able to actuate the LSD. That's exactly what happened as most of the time the 4x4 worked fine. I found out when I got home the 4low is definitely working correctly. So that means it's time for a locker! I don't really want to lock the 30 as I'm running a tiny pinion gear as it is and I would also have to re-set the gears again with the new carrier. So I think it's time for a new axle!
I didn't want to settle for less than a ProRock since a new axle is an expensive purchase. Do it once and do it right. And now after talking to Dynatrac, they said they think they can build an axle for a WJ. :rock: Previously I was told they probably couldn't because of the coil brackets not being available. They are available now, so I sent Dynatrac the part descriptions and specs and they think they can work with it. That takes a huge stress off of me having to build it myself which I really didn't want to do or settle for a cheaper axle. The only other WJ 44 available now is a JK Rubicon axle that's had modified brackets, still a good axle but not a ProRock.
Only catch now is coming up with the money! Hopefully soon though.
It sux to have to spend the $$, but that's awesome!
