I prefer to run my aux lights on the bumper above the fairlead. Windshield lights are nice and will get them up higher but, they do glare on the hood. Most people are okay with this but, I find it a little distracting.
That's what I was thinking with the glare. What kind of mount do you use with the offset roller fairlead. I've only been able to find mounts for centered fairleads.
Evo makes a offset mount
On our white Jeep, I drilled a hole on top of the driver side roller mount, stacked a couple of thick washers and attached a light there. On the passenger side, I drilled a hole there too but bolted on a piece of bar stock to offset the light.
On our dozer Jeep, I just installed an EVO light mount and it does the same thing![]()
Aren't they more likely to get smashed if they're on the front like that? I figured I would use the windshield mounts for that reason.
that's a good point as well but i think having a stinger or some kind of bar would protect them just fine.
as others have said evo does make a mount....but i still cant find it anywhere....guess i should just call evo direct but rather go through northridge since i need to order other parts
Is this better / worse depending on whether you're running a flood / spot pattern on the beams or glare is glare and it's don't matter?
Eddie, I assume you run them the same route as the winch wiring, but what did you do to keep the light wiring clear from the winch cable and still make it look nice?
I'll try to take a pic and post it up soon.
Here you go...
Basically, just wrapped the wires in plastic conduit and routed them around the winch. :yup:
Maybe it has something to do with my eyes and having a hard time with lights at night in general.
