These are some trail notes from a group I run with quite a bit. One of the members records trails as we run them and what we thought about them.
WINDROCK TRAIL NOTES
Completed
Trail # Name Difficulty Notes & Entrance Recommendations
3 Trail (6) Difficult (enter from G3) Lots of rocks and creek beds. Path to the right has a tricky end. We took the right path, which was easier. (the first half has been turned into gravel road now).
5 Trail (1) Easy I don’t recall anything tricky on this.
7 Trail (5) Difficult Really fun trail. Lots of steep grade changes (enter from the North East trailhead to predominantly go uphill)
9 Trail (4) Easy Easy trail. Its uphill entering from 12. It might be hard when wet.
11 Trail Difficult We entered from Trail 12. First hill climb had a tough ledge we couldn't get over. Not everyone had winches so we turned back. Not sure about the rest of the trail.
12 Trail (5) Difficult We entered from Trail 13. Very Technical trail. Also very tight. Lots of creek stuff.
13 Trail (2) Easy Pretty easy. Takes a while to locate. Only real use would be for access to Trail 12.
15 Trail (7)Most Difficult (enter from P1) Difficult trail with several line options to increase the difficulty level
16 Trail (2) Easy This trail is LONG and boring. The only fun spot is a exit hill climb. However you can access the climb without going on the trail via the bypass to/from G1
17 Trail (4) Moderate (uphill enter from 16 via G10) We went down hill (entering from 2). This would be a fun trail to go up hill. (Bypass most of 16 by using G10)
18 Trail (6) Difficult (We enetered from 16, this was heading down hill) There were 2 tough spots. We exited onto 28, so only saw this half of the trail.
21 Trail (7) Most Difficult (enter from 22) Longer difficult trail with several big obstacle. Extremely difficult optional hill climb at the end.
22 Trail (3) Easy A few optional places to play. It is a LONG trail.
23 Atomic Ridge Trail (8) Most Difficult (The top f the mountain contains Crazy Tough climbs. My rating is based off bypassing these) Enter from Northern Trailhead to go predominatly uphill. One real steep off-camber climb.
26 Trail (3) Moderate Lots of rocks. Its one long dry creek bed. No real obstacles.
28 Trail (3) Difficult Nice easy trail through the woods
29 Trail (2) Moderate simple trail
30 Trail (2) Moderate simple trail
31 Trail (4) Difficult (enter from 30 to go up hill) Steep hill climb. Easy enough for anyone with a locker.
35 Trail (5) Moderate Very scenic trail that has a few tricky spots.
36 Trail (3) Easy Lots of mud/water spots. There are some fun moderate hill climbs half way through.
41a Trail (4) Moderate Slick woody area with some hill climbs
41b Trail (5) Difficult Slick woody area with some hill climbs, when wet this has a very difficult hill climb.
42 Litte Fodderstack (4) Moderate (enter from 43) This trail is mainly easy. On little hill climb is tough because it is wet. An underground water source had this trail wet on a very dry day.
43 Big Fodderstack Trail (7) Difficult (enter from 44) Very Steep hill climb. One spot is likely to require winching.
44 Betty's Trail (7) Difficult (enter from 26) Steep elevation changes and slick hill climbs. When slightly wet this trail will have one nasty switchback ledge.
54 Trail (4) Moderate not much but connects 5a, 5b, 5c (very fun series)
54a Devil's Elbow (7) Difficult Very tight and technical pass, It was wet and will always likely be wet Enter from G55 to go uphill)
54b Cross Mtn Powerline Trl (6) Difficult A few tricky spots. One ledge that is very difficult.
72 Beech Grove Trail (4) moderate One really hard hill climb, but it has a bypass.
