Which to do first...
Your bump stops should at least be the same lenght as the advertised size of your lift. If you don't have a Rubi sway bar you'll be fine with the stock link though the should be parallel to the ground.
Yup, what he said ^^^. I would just add that the bump stop extensions should be "about" the same height. More times than not, most lift kits yield way more lift than is advertised.
Ok thank you all for the info... I'm hoping to get this install done in the next 2weeks or so.. So all advice and parts are in process of getting purchased
