Kneece
What is the MPG difference?
At 32 I was getting 13. At 50 I get 17-18. That is not the display on the dash. It taking miles/ gallons I pump in.
Sent by Pony Express
Wow 18mpg shit I may go for 80 psi than lol
If I get anywhere close to recommended PSI on mine my ride starts to get a bit flighty
I tried 65 but it rattled my fillings loose. So I started taking 5 psi out at a time. Now I'm not saying it's a smooth ride but, it's a Jeep not a Cadillac.
I'm really surprised nobody has said it yet, or maybe I missed it but some people do the "chalk test" across the tread.
What is that?
Make a chalk line across the tread, drive the vehicle a block or so and see how the chalk rubs off. Too much air will cause the chalk to wear from the center, too little air and it will rub from the edges of the tire. Theoretically, you want uniform wearing across the tread.
Sounds like a good idea. Thanks for the info.
And also, the reason for using chalk and actually driving the vehicle rather than a straight edge while parked is because tires actually "stand up" when you drive, similar to a dragster's tires just not as noticeable.
first off brankz make sure your tire can handle that much pressure, and 2ndly that might be the peak fuel economy with the tires, you also have to factor in tread design and driving style
I run about 28psi on 35s. I found that to be a comfortable ride.
I have 38,000 on these tires. Just make sure you are running the manufacture's recommended PSI not 32 or 35. You will get a butt load of life out of them. View attachment 74638
80 psi on 33s? Your crazy bro!!! That's way way wayyyyy to much air for a tire. Just because it says 70 or 80 dose t mean you have to use that psi
