Lexiewalker
Going to be installing some locking lug nuts. Specs say 85-115 ft lbs if I'm not mistaken. I drive a 2011 2D rubicon. Wondering what y'all keep yours at?
I go to 100 ft/lbs everytime. Just an good middle ground number lol
Unless its squeakers that was about 5 ft/lbs and my wheel fell off thanks again steve
95 for both and red lock tight on the adapters you don't want those suckers coming off or getting lose you can even do a fine paint line on the bolt and nut and check them the first 100 miles and very oil change to make sure they are tight.
:dont_tell: shhhhhhh
memo to self.....bring own torque wrench to Raucsh Creek in September...check.
Torque the lug nuts dry, don't use any type of oil or anti-seize on the studs. It seems crazy, but if you lube the studs the clamping force is actually reduced even when the lugs are torqued to spec. You would think just the opposite would be true.
Haw iv never heard that but yeah I can actually see what you mean makes sense I'll check them out after a few miles and see what's up on them then. Thanks for the Intel.
Went through my source material again, 30wt oil on the stud will increase clamping force, a anti-seize decreases clamping force. So I was partially right.View attachment 214834
Oh my god, really!?!!? You are kidding right?
By lubing the inclined plane that is the threads, you increase said planes efficiency, thereby increasing the clamping force. YOU have it completely backwards. Check out this reference:
http://waset.org/publications/7105/...fect-of-bolt-threads-lubrication-on-its-value
It states "Generally, lubrication of bolt threads causes the friction and torque coefficient to decrease and so the clamping to increase."
Please PLEASE stop spreading incorrect information on this forum. To me it just makes common sense that lubricated threads create less friction and thereby more clamping force. When you deal with Loctite, thread tape, etc you have to DECREASE the amount of torque applied to get the same clamping force value.
I had never heard anyone say that either, but now you know that it is incorrect. Yes, no one should lube their lug nuts ever anyways. Just be careful when you apply torque when using Loctite.
