cozdude
Guy with a Red 2-Door
Because you got a free hoodie?Can anyone explain to me how the Snap-On Guy was able to convince me to buy a $600 torque wrench?? Please use small words.
Also built in torque angle
Very nice! Been looking at these for my front bumper also.Got the Rigid 360 installed. Wow are they bright at night. They sure help getting off the trail after sunset.
do you think the wire was the cause all along?Adjusted the soft top to fit better
After all the top end work on the engine, was plagued random CEL codes which were kicking the Jeep into limp mode. Finally traced the problem to a wire with a cracked insulator that I missed before. Applied some “liquid tape” and drive it for a few days. No more codes. Borrowed a demo scanner from the Snap On guy and performed a complete system relearn. Now she purrs like a kitten and mileage went from 15 mpg on the freeway to 18-20.
No. The wire certainly was one of the issues complicating the troubleshooting tree and, short version, triggered an investigation that led to identifying problems with the cam phasers and rockers. Three or four rockers had a bit of play in them.do you think the wire was the cause all along?
Nice job, Looks great!Renegade decal is on! What a PITA
Holy hell!! That pumpReplaced my vacuum pump. Not sure it really needed to be replaced
Then pulled the blue ARB lines and replaced them with SS. Thanks to @wayoflife for the writeup thread. Made sourcing parts a lot easier.
If you ever find the cap, I don't want it back.Holy hell!! That pump![]()
Gotta love the rust belt. The Zeon on my JL looked like that as well. Getting a cover to fit on one of these mounted in the factory steel bumper isOne more killed by the salty elements plus bad owner maintenance. This is an early Zeon. I rebuilt it once in 2015 with a new drum, brake kit and buss connection. This time, I didn't get that far. I couldn't rotate the clutch disengagement without the help of channel locks, so the only way to replace the rope was to unspool it using the motor. That was a bad idea. I should have pulled it all apart first and just left the old rope on the old drum. I got the whole rope unspooled and cut off, but the effort was too much for the old winch. I smoked it, but at least it happened in the garage and not on the trail. Time for a new one.
Is there a good waterproof cover for these? Something that is reasonable to put on and take off a Zeon 10-s recessed into the bumper? There are 100's on Amazon I could randomly pick; didn't see one on Eddie's Amazon store. My bumper is the Expedition One Core, which has a winch hole similar to the Evo 1/4-pounder. The old neoprene cover I used to have really didn't do much other than keep it wet longer and fade to gray after the first year. Maybe a Hefty cinch sack.
BTW, here is a link to the Zeon service manual if anyone wants it. It's 2014 vintage but I couldn't find a new version on their website:
Warn Zeon Service Manual
Dave
Thank you for posting that up. I just went through mine a little also as it is a 2016.. not really sure about any other covers for the winch itself. I just use the Warn plastic cover for the front to help protect the rope from UV and some of the road dirt and grime. It has worked well for me and kept the rope in really good condition over the years.One more killed by the salty elements plus bad owner maintenance. This is an early Zeon. I rebuilt it once in 2015 with a new drum, brake kit and buss connection. This time, I didn't get that far. I couldn't rotate the clutch disengagement without the help of channel locks, so the only way to replace the rope was to unspool it using the motor. That was a bad idea. I should have pulled it all apart first and just left the old rope on the old drum. I got the whole rope unspooled and cut off, but the effort was too much for the old winch. I smoked it, but at least it happened in the garage and not on the trail. Time for a new one.
Dave
I’ve been really happy with the Bartact winch cover. I’ve had it for maybe 4 years now and doesn’t even look too sun faded. https://www.bartact.com/products/winch-cover-for-warn-zeon-10-and-12-patent-pending-bartactOne more killed by the salty elements plus bad owner maintenance. This is an early Zeon. I rebuilt it once in 2015 with a new drum, brake kit and buss connection. This time, I didn't get that far. I couldn't rotate the clutch disengagement without the help of channel locks, so the only way to replace the rope was to unspool it using the motor. That was a bad idea. I should have pulled it all apart first and just left the old rope on the old drum. I got the whole rope unspooled and cut off, but the effort was too much for the old winch. I smoked it, but at least it happened in the garage and not on the trail. Time for a new one.
Dave
