duktrx
It finally happened, coming home from a doctor's appointment I was accelerating to get on the freeway and crossed the 40 MPH mark, hit a bump, and got the Death Wobbles. I had several bouts of the DW in my old Ram 2500, but it had enough mass that it did not feel too bad, in my Jeep, it created a sense of death, partially due to the fact a semi was right next to me.
Got home and felt around for loose bolts and worn bushings. The tie-rid felt suspect, so I pulled it, and sure enough, the passenger side moved laterally and the boot on the driver was blown and had a rough gritty feeling while moving it around. Replaced the tie rod and ends. Since I was under the Jeep anyway, I pulled three of the four control arms, the track bar, and the drag link to inspect the bushings and ends for wear. All looked good, the passenger's side upper control arm is the one I didn't/couldn't inspect the frame side bushing. The bolt is stupidly captured by the catalytic converter . I assume the solution is to cut the bolt and replace it with one from the other direction.
Took it for a road test and hit bridge joints, potholes, and hit 65+ speeds with no sign of a shimmy or shake. Then installed the steering stabilizer.
