Zachp28
Zach, great looking Jk, make sure to trim your rear rocker pinch seams, from the pic looks like the tires will get pretty close when flexing.
Thanks brother! Been thinking about doing it the past few weeks.
Finally got a winch on my jeep. Now I just need to go get stuck so I can use it!!
Had a blown speaker for a couple years. Finally pulled the cage and installed new separates. Sprayed silicone lube between all factory cage friction areas and tightened all cage bolts as everything has been squeaking bad. Noises all gone. Added another rotopax mount to my deck to hold 8 gallons, added some d-rings to it. Added a 12 volt outlet running 8/10 gauge wire for the fridge or whatever needed. Don't need to unplug the fridge to charge something without the key on anymore.
New tires!View attachment 205367
Is this with the 4" coil lift or the 2" spacer lift?
TeraFlex 2.5 BB w/ TF shocks and 35" tires (spacers) the front spacers are 2.5" and the rear are 2.25"
It looks sweet. :rock:
You still have plenty of room for some mad articulation.
Thanks! 5.13's are coming next.
Literally just hit my doorstep. Yeaaa buddy. 1350 front DS.
