jesse3638
Yeah I hate that too. I don't care how long it takes just keep me up to speed.
Just realized I dented my rear shock last time out. Is it toast? Or is there some give inside the shock body? I haven’t noticed any difference in handling... but haven’t been paying attention to it either.
If that's a Rancho 5000, you should be fine as it has a twin tube design.
9000... knob is turned in.
Same thing. You should be fine. If in doubt, you could pull the shock and try to cycle it by hand. So long as you don't feel any hang up, you should be good to go.
Kirk
Mine are dented worse than that and they still work fine.
You have a long ways to go before it is a problem.
Anybody have that popping creaking sound on driver side under dash?
Yep... intermittently and right about the time I pinpoint it, it goes silent. Like it took lessons from a cricket. Frustrating as hell.
I disco'd the sway bar, played on some dirt piles, and now the sway bar won't reconnect. The light just flashes.
I checked codes, and the only thing showing is the right and left headlight, low beam voltage low, or something like that. Those codes have been there since I bought the Jeep.
You can try fiddling around with it to see if it’ll fix. Same thing happened to mine. After messing around with it for a while, including checking for mud and water intrusion, followed by swapping in a different motor, no dice. I eventually went with an EVO no limits manual disconnect and turned off the flashing light with a Pro Cal. Not as handy as a functioning electric sway bar disconnect, but way better than link disconnects.
