Clifford33
Mall crawl'n... the struggle is real
Tell me about it. Those parking blocks and curbs are a challenge man. Time for 40’s and coil overs.
It was both on high [emoji1303]
Edit: here it goes.
3.6L V6 Thermostat Housing Replacement
I’m not going to say i followed those instruction to a t, but I think I was pretty close. Changing the water temp sensor I thought was slightly more difficult only because of location. Either way, topped off coolant (yes mopar OAT) and burped. Check engine light shut off in the 40-42 mile range.
Honestly, I have plenty of coolant. I should have just done a full flush. I’ll have to get around to that another time.
The other day, I hit a puddle of slush and instantly started to get a chirping noise. An unbelievably annoying and embarrassing noise when you’re going slower especially in parking lots [emoji51] the noise ranges with speed. I greased the front driveshaft and wherever I thought the noise might be coming from but it is still there. Had the wife drive back and forth in the driveway and it sounds like it’s coming from the front driveshaft and transfer case (I originally thought it was the driver side wheel end). So sounds like I’ll be lathering more grease up there tomorrow...
Have you upgraded your front DS? If so, it’s your double cardan joint seizing up and needs to be greased and probably rebuilt.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
I have upgraded it and I was afraid of that. I’ll hit it with more grease tomorrow and look into a shop around here.
Yeah, it sucks. Sounds like a pack of angry squirrels under there.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Lol it sure does.
I sure hope it will be fine for a little while, after this snowstorm tomorrow I’ll pull it off and hopefully this shop down the road from me rebuilds them... (just sent them an email)
Mine was a non greaseable joint and when it failed I had it replace with one that was. Now i grease it at every oil change.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
I’m not as good about greasing as I should be... I’m certainly going to try and grease more often! What was the cost of them rebuilding it?
It’s been a year, but to replace and rebalance mine was like $150 I think.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Could it possibly be one of your engine pulleys. My tensioner pulley would chirp for a couple days whenever I got the underbody wash at the car wash. Finally swapped it out when it kept doing all the time.
That’s what I was gonna guess. Especially since it happened after hitting icy water.
It's definitely beneficial to both people in the relationship.
