RageKage
I got the dreaded oil cooler/ filter housing leak.... yay me. And not a moment after I fixed my wife’s truck and got it back on the road too. Smh.
Yup. It's been a constant battle, but this time I'm pretty sure it was my fault. I probably pulled my soft top too tight when I replaced it recently. The good news is, it appears that the leak I had at the corner of the windshield is still gone.Jeep salesmen told me “ if you don’t want water leaks, don’t buy a wrangler “. How true. [emoji482]
I'm guessing here. I managed to run up against a big piece of the planet a couple weeks ago that didn't move. My front driver tire ended up turned right to the stop and jammed up against the rock. I had to back up and try a different line. Didn't seem like a big deal, no sudden impact or lurching, just normal crawling. When I got off the trail the steering wheel was rotated 15 degrees to the right and the Traction Control Light came on.. The code won't clear. The alignment is still fine she tracks down the road with no pulling. I just figured the clamp was loose and had rotated/slipped on the drag link but not the case.
While I had her in for something else, my shop guy checked the code and told me the steering column intermediate shaft rotational sensor is saying its turned 70 degrees out from the other sensor which is zero'd. Has anyone seen this before? Can you point me in the right direction to fix it. The shop didn't recommend a fix, maybe they didn't know or maybe they didn't want to tell me how much. It was right before the holidays and they said bring her back after xmas and we'll take a look. It's a 2011 JKU sport, running stock steering box and original steering assembly and Pitman arm. 99,000 miles. ProRock 44 axle and upgraded front end on a 2.5 RK xfactor lift.
Sorry for the bump but I could really use some ideas if anyone has seen this before. Thanks
You likely bent the drag link. Straighten your steering wheel (easy and free) and see what happens. Start there.
Thanks! Would that solve the problem of the offset between the rotational sensors? I’m not sure where they are.
I did the exact same thing a couple of months ago. My drag link got bent upwards slightly an the steering wheel was half turned. I just center the wheel by readjusting it.
Coolant leak
Oil cooler leaking
Tie Rod and drag link loose! I can wiggle them with my hand, they move pretty easily. Recently changed the cartridges in them and they are loose again!! Can’t get them to button up correctly! About to switch to Synergy set up.
View attachment 317978View attachment 317979View attachment 317980View attachment 317981
Rear track bar mount [emoji29] some what of a fix till I get a new one
Is that some kind of aftermarket bracket that is really long? With that much leverage it will keep breaking
My CEL just came on on the way home. P0305, cylinder 5 misfire at only 28k miles.... such a bummer since we are supposed to be camping this weekend with my sons scout pack, and 4wd is required to get there.
