rubiDave
In other news, my NY19 T-shirt finally arrived yesterday.
Thanks, LuisJK and Ray is coming over for New Years. It’ll be a drinking installation weekend..
It’s either going to be great or be a shit show![]()
Almost 110 mph!!
One of these days I’m going to stop fucking with my Jeep long enough to make something like this.
What kind of cable and antenna do you have? I run the same CB and had bad luck with the fire ring cable and their 3' antenna. I had to get a coax with standard connectors and a 4' antenna to get it to work well.Still struggling with the CB . Added the grounding strap and SWR is still off the charts above 3. Next step is trying a new coax cable and a multimeter for diagnosis . Any chance the radio (cobra 75) could be bad?
I
The bracket the antennae is attached to... is it painted? Did you expose the metal? Is your ground at the control box solid to clean metal as well?
Just so that we're all on the same page, you are making sure that the shoulders of the nylon washer are seated inside the mount hole, right? It's critical that the stud does NOT make contact with the mount and that nylon washer is designed to help prevent that.
Teraflex bracket is painted . I scraped off powder coating on the hose where antenna is mounted but didn’t do this with other bolts to tailgate yet ... figured the grounding strap would solve this ..
Ground is at control box in glovebox . Ground runs to battery
