Juanzy07Unlx
I have a 07 jeep wrangler unlimited x, its not a daily driver, maybe 1 or 2 times a week I wanted to know how would the drive be if I put 37s on it,
Stock gears? Im running 37s and stock gears, my jeep is dd and it ain't bad. Shouldn't have any trouble
Sent from my SM-G935T using WAYALIFE mobile app
my JKUR is on factory gears and 37s i put about 100 miles on it a day... no issues just slow :cheesy: Welcome to wal
It will get you to the mall and back just fine.
Don't hit any speed bumps too hard tho...
There arent any guys on here who would run 35's on that axle without reinforcing it. 37's are just piling on.So is it that much of a different ride than 35s
You might be fine, and never have an issue. Or you might grenade it the first tie you bump a curb in the Jack in the Box drive thru.
You have a Rubi, with a 44 up front. People run 37's on those easily, and 35's all day long. OP has a sport, or an X, I don't remember...either way he isn't running a 44 up front.I've run 35's on stock rubi axle and gears for 3 years no problem. Will be upgrading to 37's and regear soon with stock axles still.
If you're only planning on see driving I would stay with 35's. No point in stressing the axles with a heavier tire or adding to the costs of said tire. It will look just as good. Abs be just as capable a pavement princessYea I don't plan in doing any offroading or anything just normal street travel
Shouldn't have any trouble. I can tell you from personal experience that you can still wheel the crap out of it. I would suggest front c-gussets and definitely a plan to regear in the futureYes it stock
I run 35s with no reinforcement.There arent any guys on here who would run 35's on that axle without reinforcing it. 37's are just piling on.
