Hard mounting a full size CB Radio, HAM, GMRS or race radio along with a tall exterior antenna, is the best way to get good reception and have the greatest range. Fortunately, installing a radio inside a Jeep JL Wrangler is a piece of cake or at least, if you use one of my CB BARs and it can be just as easy to install an antenna on the tailgate, especially if you use one of my stainless steel mounts. In this video, you'll get to see how it's done as well as how to get the cable inside your Jeep and routed cleanly to your radio.
NOTE : This will work on a JK Wrangler as well but you will need to remove the tailgate hinge cover.
SUPPORTING VIDEOS
CB BAR & Aux Switch Installation Video:
CB BAR Installation Video:
WHAT YOU WILL NEED
CB BAR: https://www.wayalife.com/store/proddetail.php?prod=PARTS-CB-BAR
CB BAR Switch Mount: https://www.wayalife.com/store/proddetail.php?prod=PARTS-CB-BAR-SWITCH-MOUNT
JL Tailgate Antenna Mount: https://www.wayalife.com/store/proddetail.php?prod=PARTS-CB-ANTENNA-MOUNT
Antenna Stud Mount: https://amzn.to/3Pnyb1a
Coax Cable: https://amzn.to/3QqaxCz
60" Ground Strap: https://amzn.to/3K05BSz
M10-1.5x25 Bolt
M10-1.5 Nut
CB Radio Firestik II 3' Antenna: https://amzn.to/3c04MMV
or
VHF No Ground Plane Antenna https://amzn.to/3plTaah
NMO Style Base (adapter plate needed): https://amzn.to/3QsnDzi
TOOLS YOU WILL NEED
Torx T-25, T-40, T-55 Bit
15, 16mm Socket
5/16, 5/8" Socket & Wrench
Ratchet
1/4" Drill Bit
Hand Drill
Plastic Trim Pry Tool
Flathead Screwdriver
Wire Cutter
Pliers
Utility Knife
Pick Tool
Zip Ties
RECOMMENDED BUYS
Milwaukee 3/8 Electric Impact: https://amzn.to/3dxW48Y
Milwaukee Ratchet: https://amzn.to/2RaT7MT
Milwaukee Drill: https://amzn.to/3JTdetT
Tekton Bit Set: https://amzn.to/3gkE7
Plastic Trim Tool Set: https://amzn.to/3gj1DnF
Pick Tool Set: https://amzn.to/3SPGQwn
Retractable Mic Holder: https://amzn.to/3SPEKwv
* Please note that the Amazon links posted are associate links and WAYALIFE does earn a small kickback for purchases made through them.
#antennamount #cbradio #jeepjl #installation #wiring #jeep #wranglerjl #jeepwrangler #jlwrangler #wranglerjl #wrangler #jljeep #wayalife #cbbar #pippiproject
SUPPORTING VIDEOS
WHAT YOU WILL NEED
M10-1.5x25 Bolt
M10-1.5 Nut
or
TOOLS YOU WILL NEED
15, 16mm Socket
Ratchet
1/4" Drill Bit
Hand Drill
Wire Cutter
Pliers
Utility Knife
Pick Tool
Zip Ties
RECOMMENDED BUYS
