Yup, this ^^^^You can just run a relay. You don’t need a resistor. I had a lightbar hooked up to that on both the two door and the silver Jeep.
With the factory bumper, you can always install them on something like these https://amzn.to/2YRS63VThose are sweet! I've been planning on mounting mine in the same spot and have been trying to figure out fabricating brackets. Where did you get that light bracket? That's perfect.
Actually, I had a brain fart and just remembered that you have a WARN winch plate for a bumper. The light mount I have is made for the EVO Quarter Pounder front bumper and it gets sandwiched between the fairlead. I'll bet you could use it for your bumper setup too.Those are sweet! I've been planning on mounting mine in the same spot and have been trying to figure out fabricating brackets. Where did you get that light bracket? That's perfect.
I'm running the warn winch plate.With the factory bumper, you can always install them on something like these https://amzn.to/2YRS63V
Or, with the Rubicon steel bumper, you can get the winch guard and mount them on top of it. https://amzn.to/2XeRd4J
Here: http://evomfg.com/index.php?route=p...ory_id=0&description=1&model=1&product_id=252I'm running the warn winch plate.
Perfect. I had no idea someone built something like that. That's what I'll get. Major time saver.Actually, I had a brain fart and just remembered that you have a WARN winch plate for a bumper. The light mount I have is made for the EVO Quarter Pounder front bumper and it gets sandwiched between the fairlead. I'll bet you could use it for your bumper setup too.
You bet! Surprisingly affordable too.Perfect. I had no idea someone built something like that. That's what I'll get. Major time saver.
I installed a pair of KC Flex single lights and added amber lenses to them.Eddie would you mind sharing what amber lights you have the back of your Evo rack?
I really do like how compact they are and yes, they really don't block the radiator much at all. Glad you enjoyed the video.Yup, I think I’ll be ordering a pair. They also don’t block much air flow to the radiator like the AEV ones that had come on my build years ago. Awesome video and demonstration of the Era 4s
And not the 10mm I guess?... annnnd there is the wrench.
This is the truth! I hope for KC that they can get their supply chain more up to speed and soon.Great video. Only downside to these lights is that they are so damn hard to buy.
Thank you. On a JL or JT, there is a white wire with a brown tracer going to the DRL that should do the trick.Great video indeed. I have my red bezels seating around but no lights yet. Anyone knows which factory wire I have to tap into in order to run amber with DRL’s?
AwesomeThank you. On a JL or JT, there is a white wire with a brown tracer going to the DRL that should do the trick.
I should note that this is on the passenger side of your Jeep.Awesome
Thank you sir!!
Spread or spot?I installed a pair of KC Flex single lights and added amber lenses to them.
This ^^^^
