Do you have a slip yoke eliminator?
Could be vibes from your rear driveshaft
I also see in your profile you have new tires. If you've had the lift for a while with no problems, take your jeep to the tire shop. Out of balance rear wheels will make your seat vibrate. Maybe you threw a weight.
Bad wheel bearings will also create a humming noise at highway speeds. If they are shot you will most likely see grease/oil on the inside of your wheel or even on the ground where the jeep is parked.
Ok so I should balance the tires and change the wheel bearings.
