Unlimited Deuce reborn (Hemi, 60s, PS Armour, Etc)
Mizippi
Ok. I have owned a 2008 JKU from new. I got hooked wheeling in the area. Jeep and beautiful wife:
So...I had to go big. I have spent the last year figuring out how to do it. I landed on finding a very high mileage CHEAP 2WD JKU. (That's right a 2wd!). Meet Deuce:
She's a 2007 X with 183k miles. Drives very very well. Started on the build in April:
Suspension:
- JKS - Adjustable Track Bar - Front
- JKS - Adjustable Track Bar - Rear
- Antirocks (Front/Rear)
- EVO bolt on coilovers (front & rear)
- EVO Long arms
- EVO Front Airbumps
Drivetrain
- 5.7vvt Truck Hemi (and Trans)
- Front - XD60 - 5.38/ARB
- Rear - UD60 - 5.38/ARB (the XD60 full float was not out when I bought)
- Mopar extended parking brake cables
- ARB Twin Compressor
- Atlas 2-Speed (w/Accessories)
- Custom Drive shafts
- ATX Pro Chambers II (black)
- Maxxis 40” trepadors
- PSC Cylinder Assist
Misc
- SPOD Switch panel
- Dual Battery Tray
- 2 Optima Red Top
- Dual Bat Isolator kit
- Custom exhaust
- Tinted front window
- Cobra 75WXST CB, wiring, etc.
Armour
- P. Spyder Cage (w/ Hardrock C-pillar)
- P. Spyder Front Fenders
- P. Spyder Rear Fenders
- P. Spyder Rear Corners
- P. Spyder Brawler Rockrail
- P. Spyder BFH Front (Brawler and Tabs)
- P. Spyder BFH Disco Skid
- P. Spyder Winch Fairlead Mount
- P. Spyder Aluminum Hawse Fairlead
- P. Spyder Hawse 10in Light Mount
- Rigid Ind. E Series Flood/Spot 10in
- Rigid Ind. Side shooters (A Pillar)
- P. Spyder BFH Rear (Receiver, Tabs)
- Hard Rock skid plates (transmission, transfer case, EVAP)
- EVO Body Tire Carrier
- Warn 10k Winch w/ Synthetic Rope (Zeon 12-S in the future)
- KC rock lights
So you just bought the Jeep for the tub/frame? You will be adding a trans, tcase, drive shafts, etc?
Looking forward to the build!
As for axles why the ud60 and not a pr60 or xd60 like your doing up front?
First step was to swap some parts from the 2008 to Deuce:
While the goodies started pouring in:
I have thought of going this same route on a build for my next jeep. Why buy all the stuff your just going to tear out and replace. Can't wait to see how it turns out!
To the op, make sure in your list of misc to add the mopar brake booster/master cylinder to the list. The UD60 brakes are amazing... if you get the bigger master/booster. With the stock one they are downright bad as it can't push enough fluid. Something like the teraflex/j8 master helps but the full blown upgraded booster is the way to go. In hard braking events now, like folks pulling out in front of you, with the bigger booster / master I set off the abs with my 40s. The brakes are actually my favorite part of the axles for normal driving.
Just out of curiosity, if you're swapping in a HEMI and F/R 60s, why in the word would you use a ProComp lift?
I was wondering this exact same thing. Your spending some serious coin on the drivetrain then falling off on the lift...
I owned the springs already, and I am going to do full coilovers at somepoint. Call it phase 1 for now
