dlm_jku
I have small LED light on my spare, it's connected to an S-Pod that was installed by the previous owner. I was wondering if it would be possible to wire it up to function as a reverse/backup light as well? So it would come on when I hit the switch on the S-Pod or when I put my Jeep (manual, if that matters) in reverse. I was thinking if I can tap the reverse light wire (if accessible somewhere under the hood) and run a wire from that into the corresponding S-Pod switch wire, to trick the S-Pod into thinking the switch had been turned on when the reverse light wire is hot. Does anyone know if this would work? And if so, where I could find a reverse wire?
