Looking good. Did you get your new steering box in? I remember that's what you were waiting on to put in the front CO. Also, I bet you were sweating your butt off!
Lookin awesome! Just wait til you take it out for the first drive when you''re done. You ain't gonna believe it. Once you hit 85 and it's like, whaaaaaaaaaat?! Where's all the drama? Why didn't I do this sooner?! :crazyeyes:
nice! definitely going to keep up with this as i'll need some references! wheeling your jeep is top of the list for a good day, but wrenching on your jeep is a close 3rd!
Thanks! I can't wait to feel how it rides. I'm guessing your really enjoying the long arms?
Absolutely! Really start noticing the difference 50mph & up. Lower speeds not as much. When you're cruising along at 80 you'll see!
JKbrick asked about the vertical joint on the rear of the front upper CA. Would you be able to take a pic of the joint & what the bushings look like & post up? I didn't think to do that.
I went with the "normal" long arm. The high clearance kit cannot be bolted on and the difference in clearance shouldn't be a big issue, these brackets are beefy.
Good to know. I'll still with the normal long arm.
I didn't think you could use the high clearance kit unless you went with the Evolever? Maybe I'm wrong but my understanding is with the high clearance kit you cut off the CA /shock mount bracket off of the axle and fab a new one with the pieces provided. There's nowhere to mount shocks/coilovers.
Dynatrac axles showed up today! Dang crate weighs 1180lbs! :shock:
You might be right about the high clearance kit, I'm not really sure. I just know its 100% weld on.
Here is a couple photos of the joint.
You can actually. All you need to do is fabricate some rear lower shock mounts. Rubicat used to have this done and I think another member here just did this on his 60/60 set. Adrock?
CONGRATS!!
Congrats!!!
That's a lot of weight.
CONGRATS!!
