Bingobelle
Hi
I watched and read Eddies guide how to set toe in and toe out. It is more or less crystal clear how to do it but one thing I still wonder about.
Does it matter if you take the measurement from the center of the tire or can you take it from the outer side of the tire? I´m thinking it can be helpfull to clamp a straight leveling bar or something becuase it is easier to measure on.
Can you do it on the rotors and if so I guess you should use some kind of bars attached to the rotors but how long out from the rotors? And also, this measurement should be affected with how big tires you have if you do it with the tires on. Is 2 to 3 mm also good for a 35 inch tire?
Thanks
Thanks
