Yes it was the Crawler Conceptz body mounted carrier.
I can certainly upload some, I'm at work at the moment though.
There was multiple fitment issues, not like a "tight tolerence to not rattle" type of fitment.
It was really poorly cut. The tire carrier W shape portion that attaches to the carrier had the bolt holes off by ~1/2 an inch.
I had to re-drill that and grind the top of the slotted portion to get the bolts through.
They also hit eachother underneath due to the bolts being too long, so I couldn't tighten them all the way.
Brackets also needed to be put into a vice and opened up. Hammered my tailgate arms(?) into the bracket for at least half an hour and they wouldn't fit.
Now the tailgate feels extremely heavy to open. I assume this will loosen up over time.
Tried painting it a couple seperate times, still not sticking. Taking it all apart again tomorrow and going to try another time.
Another part I just remembered, the wheel stud mounting plate had the holes drilled too small. The wheel studs won't fully seat even with an air impact.
When I take the spare off, the studs just fall out of the slots. So I have to try and lift my spare (37) while fiddling with these wheel studs :/
