My Sport decals have started peeling, I had ignored it but today I looked at the one on the driver side and it looks bad, any tips on how to remove the adhesive after I pull it?
This ^^^. It's called an eraser wheel and just about any auto parts store will sell them. They work like a dream.Auto body supply shops sell an attachment for the end of a drill that is like a big pencil eraser and it basically just rubs off the decal and adhesive.
If you have a heat gun that'll work too. Get it good and hot and a plastic squeegee will scrape it off. Use WD40 on the leftover adhesive.
Heat gun is dangerous on paint. I use a hair dryer to heat up the decals and pull them off. I use lighter fluid and a rag to remove the adhesive. You can also use WD-40. Make sure to re-wax the area after using a solvent.
Some heat guns have 2 settings![]()
I should reword that to "Heatguns are dangerous to paint with me operating it."
Don't get me started on power washers are dangerous to patio furniture.....
That 3M stuff is really strong. Definitely give it a good wax after to protect the clear coat.lol, other than plasma cutter, if you peeled of most of the sticker and only have the sticky/glue part left. This should take it off pretty easy, just spray it on, let sit for couple minutes and it should wipe right off.
