NorthCountry
Greetings, I recently purchased a used 2023 Gladiator Sport. I was hearing a noise from the front end and crawled underneath to look around. I had my buddy rock the jeep and found that the noise was coming from the lower sway bar disconnect stud. I disconnected the link and put a punch into the spring clip hole in order to crank a wrench on the locking nut. Punch snapped right off. Is there a trick to holding the stud while tightening the nut. I don't want to damage the surface with vise grips or anything like that.
Another quick question. Its obvious they installed a lift kit, but I'm not sure what size. I did see that the front coil springs are stickered 340. Any ideas?
Thank you and safe travels.
