so this would be ok?
Who out there has a different third brake light what did you do for wiring???
Or use something like this View attachment 54820
Cut the 3rd break light wires and install those on the all the wires. Male ends on the antenna and on the 3rd break light so you can run what ever you want. Make sence?
I'm guessing if the light is seperate from the antenna, you wouldn't damage anything. You'll be okay!
Sent via secret squirrel underground network.
Sweet and you havent had any problems, what voltage where the lights thats my only big fear.
Went to the local auto part store and picked up these 3/4 led lights and wired them up in the spare lugnut holes with quick connectors in case I need my spare.
about 14 bucks and 20 minutes. Had to drill 2 holes for wires and connectors to go thru.
Don't know the laws for 3rd brake lights in my own state of Md let alone anywhere else, but aren't the third brake lights supposed to be mounted higher up on the vehicle like what would be in plain sight if you were looking at the rear window? Like I said I have no idea but was considering doing the leds on the spare's lug nut holes and I'm questioning whether that is a legal location.
Thanks for any guidance on this.
ok so im not a master at engery here
Im sure the law varies state to state. I didnt even run them in Mississippi.
Recently moved to Utah and had to have them to pass inspection. It passed, so im happy with them.
With a 37 on the back it would have to be almost on my roof for a close following car to see. These are about eye level to the average car.
im in PA and currently i dont have a third brake light on my jeep. My stepdad is a cheif of police and said a cop will not bother you for no 3rd brake light (this has held true for the past 3 months or so) he did say that for inspection i will need to find a way to wire it up so i can pass. other than that its not needed
He lives in MA where they'll pull you over for dealer license plats brackets being 1% out of regulation. :banghead:
Any lights near or on your antenna will render the antenna useless when the light is energized
How's about a write up or part numbers for your mod. I like it.
