Hummm, although this is a great thread, i take some exception to the measuring methods. i went out and measured my new jl 2019 jeep tires(I'm new, haven't figured out how to post photos yet). i used a square clamp and measured like a caliper in the center of the wheel while hanging on the wheel rack(no weight). the tire is 245/75/r17 printed on the side wall. this metric equals 31.5". the tire measured 31.47". then i did as the post instructions requested, and went to the ground up measurement. it was 30.9375. the .5" difference is the "belly" of the tire sinking in a bit. all tires do the same thing. at 30 psi the tires still have the belly sag. the second issue is how we look from the tape measure to the tire thread, and at what angle. if a 12" level was laid across the tires, and measured would be more accurate. by analyzing the data posted, there is a direct correlation by the tire sizes small to large by the difference of the stated size vs actual size. as 1 example an BFG MUD_TERRAIN T/A KM3 lt295/70/r17 states the overall diameter at 33.3" at proper pressure. the company states the max psi is 80 psi. if this tire is deflated to 30 psi im not surprised to see a 1.5" to 2" smaller measurement. bfg's "35" is stated to be 34.6". i think this is closer to correct than 33" reported here. also consider a tire rolling/spinning at 624 revs per mile, at 70 mph, is probably larger in diameter.
the question i'm trying to answer, is what is the maximum size tire i can install on a stock/no lift 2019 jl sport 2 dr Jeep wrangler? has anyone had first hand experience ?
