i was wanting this one for when i get mine, it uses your jeep key and made in the usa, 38 bucks.. http://northridge4x4.com/shop/bolt-lock-jeep-chrysler-5-8in-receiver-lock-by-bolt-lock-7018448
A 5/8 pin won't work. 9/16 is the max. And what evo/ore supplies. I am using a 1/2" which would likely be the minimum.
Haha, I'd do the same thing. What kind of gas mileage are you getting?
More small tweaks to the pins. Added 8" coated stainless lanyards to the carrier QD pins today. Now I can pull the pins and let them dangle.
Drilled two 5/32" holes and tapped for 10-24 stainless button head screws.
30 minutes later, all done:
I'm totally OCD, so having the silver clip on the black painted corner would drive me nuts. But cool idea if you're worried about losing pins. I created custom pins using some 5/16 (I think that was size:thinking grade 8 bolts I had trimmed and hole pressed. No place to attach a lanyard.
Where did you buy those speakers?
Tinkered on the jeep today to update some creature comforts.
I also started to upgrade the stereo with a "budget" upgrade. I ditched the factory sound bar speakers and front speakers in favor of the Mopar Kicker OEM replacements. Stuffed the bar and the front speaker pods with polyfill and it has been a HUGE difference. Amazing upgrade for $140. In actuality I'm not done yet since I have to do the drivers side but that should be done tonight (but the sound difference from a simple replacement of 3 of 4 speakers has already been amazing.
Factory left, Mopar upgrade right:
Polyfill
I've been meaning to do this. I don't want to go nuts with the sound on a vehicle that doesn't have doors or a top a lot of the time, and when it does, it's never locked. Glad to hear that it will be worth it when I pull the trigger on them.
Levi
2013 CG JKU 6-speed
I was in the same mindset. I didn't want to deal with electrical problems with amplifier whine, bad connections on something I just dont care about that much. At the same time I didn't want to encourage theft with an aftermarket head unit. Still might buy the Mopar/kicker sub though...
I meant to ask yesterday, which rear view camera are you using now? Do you like it?
