I thought about that haha.Wish I saw this sooner.. I highly recommend turning the rear shocks so the adjuster knob faces the front of the Jeep. You will break them off in the rocks... Ask me how I know.
Sent from my SM-N915P using WAYALIFE mobile app
Thanks Pete. As Baddestcross said I will probably turn the adjuster knob inward. But I'll let you know how they work. Let me know when the time comes how those fox work out for you.Looks good Anthony! Can't wait to hear your results.
Are there inner and outer seals? Or just outer? I would assume both but it never hurts to ask.Bummer. Definitely want to get that fixed.
Sent from my LG-H900 using WAYALIFE mobile app
Yea I don't have a press. I'll have to take it into the dealer.There's just one seal but you're gonna need to remove a pressed in sleeve to remove and replace it. Depending on how many miles you have on your shafts, might be a good time to replace the bearings too. If you don't have a shop press, you will need to have a shop do the work for you.
I appreciate the help Eddie. You always give great information.There's just one seal but you're gonna need to remove a pressed in sleeve to remove and replace it. Depending on how many miles you have on your shafts, might be a good time to replace the bearings too. If you don't have a shop press, you will need to have a shop do the work for you.
I checked. I pulled the full plug and a little bit came out but not much. I'll have to just keep cleaning it and checking to see if continues or subsides. Thank you though.Also consider whether the guys that did your gears possibly overfilled your differential.
Yea it looks like it's coming from the flang areaAn over filled diff would pump gear oil out the breather. If it you really are getting oil out the seal, the seal is bad.
I'll pull it tonight and find out. I may be over thinking it.You could always pull the wheel and rotor to inspect, but realistically, they should be looking at this for you if it's leaking.
