bkac
Looking good bobby. I say keep the 35s!!
Sawweeeet!!! Looking good.
Thanks guys!
Looking good. I like the Jeep diff covers. Looking forward to seeing how this axles hold up.
What did you dobro have to make it work with the calipers?
Didn't the rear come with a raise track bar bracket or did you have to use the evo one?
Here's a better shot of the calipers and some of the issues noted above
1. Cool jack stands.
2. Are these are airlockers or e lockers?
3. I too, love the diff covers.
4. You're making tons of progress.
5. Can't remember.
6. Looks really good, I like your build.
These axles have the Eaton E-lockers. I'm gonna put them to the test. Only time will tell if I made a really expensive mistake.
Are they plug n play with the rubi locker switches?!? That'd be cool.
So the issues I'm working through with the evo bolt on kit with the Spicer 60's are...
The rear calipers are HUGE causing the following issue,
Evo brakelines don't really work with the angle they have on them, the swaybar links won't work with the calipers, they hit them at full drop. I'm going to try and bend them and see if I can make them work. The factory rear trackbar on the ud60s would have hit the coilovers but now with the modified evo trackbar bracket the factory trackbar hits the diff cover.
The next issue I had was the rockstars don't fit the brackets so I have had to modify the rockstars quite a bit. I could have used the factory stock shock mounts but would have lost the ground clearance. I'm making headway. The lower coilover bolt is so close to the lower caliper bolt. I actually might custom make some new coilover mounting brackets and weld them to the axle. EVO says they are actually working on a kit for these axles. The front is so far so good!
Cool thanks for explaining it all. Do you just need a rear TB that has a different bend to it to clear the is diff?
Is it both links that hit the calipers on full droop?
Moving along on the front today.
Cycling the axle through looking for issues.
Whats your impression of the axles so far. I almost got these over my prorocks.
I'm not regretting my decision yet. I'm happy with the quality, the brackets are welded very nicely and the brakes are big.
It's been a little frustrating installing them with the bolt-on kit. I was told the wiring harness was plug it ready but that doesn't seem to be the case so far. I think the rear brakes are overkill and have caused a lot of problems during the install. The rear parking brake cable location/design is just stupid along with the rear brakeline location on the caliper. I wish I could have ran slabs with 3.5" backspacing vs 4.06" chambers I have. Overall I'm very excited to see what they're made of. Not here to try and sell/convince anyone to go get them, I just couldn't pass up the savings for what they seem to be, at least for myself. Only time will tell. I'm thinking they will be perfect for my needs and wheeling, and yes, I'm sure I'll brake somethingonthem one day. I'm not running K.O.H. any time soon!
Thanks for the info. Someone I know locally had the same issue with the brakeline bolt on the caliper and switched it out to something else that looked much better and didnt stick out like the 90 degree bent one that comes stock. Cant remeber off the top of my head what it was but Id be willing to ask him if you want to know.
A new trackbar might be the solution, because of the coilovers and the bypasses, it causes a whole other issue changing TBar brackets. I might be able to even just grind a fin if the diff cover.
Yes both links hit the calipers. The front is going together much better.
